Other Parts Discussed in Thread: LM48560,
Hi TI Experts,
I am new to PCB layouts and I am current reviewing the LM48560 and its evaluation board for reference. In the datasheet, I noticed a layout guideline recommending the use of wide traces for the amplifier outputs, as shown in the attached image.
My question is: what is the typical trace width for audio amplifier outputs? Would a 20 mil width be sufficient, or what size would you suggest the trace width to be in mils?
Actually, can I consider using the 100-ohm differential impedance matching for audio analog signals approach for this IC instead?
Additionally, I tested the evaluation board LM48560TLEVAL and observed a current draw of 400mA from the power supply at max gain. Hope the information provided is enough for your inputs to my questions.
Thank you for your help!
Best Regards
Ena
