Other Parts Discussed in Thread: DRV8316
Hi friends,
I'm interested in your opinions on my advice, which was published in an article:
best regards
zbynoB
Hi Zbyno,
Thanks for reaching out. I read the article.
In summary, you are showing how the current measurement error can be removed using Kirchhoff's law and matrix reductions. My understanding is that this will be done entirely in software once the measured currents go from the DRV to the MCU.
If so, I see that you mentioned hardware testing using the DRV8316 EVM. That would be good to show the follow up once you have completed the experiment using real measured values.
Joseph
Thank you Joseph,
Yes you right, it will be done in SW of MSPM0Gxxx.I have prepared my owm design with DRV8316 C (but very compatible with DRV8316 EVM).
I will try to write this correction procedure and then I'll write you a message about the result.
best regards
zbynoB
Hi Zbyno,
Understood.
I will close this thread and you can create another related post with the results,
Joseph
