Quick question on the GVDD_X supply: I see the minimum supply is 10.8 V; what happens if the voltage drops below that? I have a 6V source, and I'm wondering if I could run it at that, or if I have to use a dc-to-dc voltage converter (charge pump).
John,
For GVDD, it is quite small at <50mA (total). For VDD, the current can increase depending on your load due to substrate current collection by the output FET guard rings.
We recommend sizing VDD current to 5% of the rated output current and no less than 100mA. For example, if your load is 10A, then VDD should be sized for 500mA. This assumes worst case under junction temperatures at 125C or greater.
