Other Parts Discussed in Thread: DRV8842, DRV8844
I am using the DRV8842 H-Bridge Motor Driver to latch a solenoid on and off.
Upon scoping the output signal from the DRV 8842, the signal seems to be a pulse-width modulated signal while switching. The current regulation feature of the DRV 8842 is disabled by connecting the ISENSE pins to ground and the VREF pins to V3P3OUT, which should disable the PWM according to the data sheet. However, the output is still PWMing. Is there a way to disable the PWM completely to get a clean latching signal on the output, and instead get a clean latching signal?
Your help is greatly appreciated.
