As according to the user guide for the evaluation module, I removed the 0.0 ohm R5 resistor to allow the use of an external PWM. To test the functionality, I connected the PWM test pin from another board to the modified one. However, my motor, which ran fine before, will not spin properly with the external signal. Is there anything else that is necessary to enable the use of an external PWM signal?
Jake
