How to implement the M/T method for the rotor speed calculation
We know there are three methods to calculate the rotor speed: M method, T method and the M/T method, but  m/t method can provide much wider speed estimation range than both  M method and T method.
The TI controlSuit has already provided the implementation approaches of M method and T method, but it seems still difficult to implement the m/t method based on the TI dsp platform. So I would be really appreciated if any one can provide the technique support to implement the m/t method based on the TI dsp platform.
Thank you!
Tao
  • Hi Tao
    If you have already decided which TI MCU or DSP platform will be used for you project, I would recommend you to post your question to dedicated forums on e2e.
    Here is the entrance link to MCU forums.
    http://e2e.ti.com/support/microcontrollers/default.aspx
    Since M/T method is the combination of M and T methods, I think it should be able to be applied in the existing platfarms which provide the M or T methods..
    Thanks and Regards,
