Hello all
I did some research and found out that if someone disconnects the motor while its running through the driver then the IC (DRV8825) will be destroyed. More generally, rewiring anything while the chip is powered is asking for trouble. So can you provide a solution for this? Any protection circuit that I can use with the IC to prevent this problem?
Arhez
