Hello.
First, please pardon my noobness, i am very new to motors and hall effect sensors and many things that can seem basic to most. Still learning.
I am trying to pilot a motor (salvaged from laser printer). It is a BLDC motor, three phases, Wye winding. Everything seems fine at the moment with that.
My problem is with the hall sensors. I have three sensors, four pins each. Two are for GND and +5v, the two others give a 2.6v constant level and show opposite curves when a magnetic field comes around. If i approach a South field, signal 1 goes up and signal 2 goes down accordingly. Same if i approach a North field, but signal 1 goes down and 2 up.
As far as i have seen from datasheet, i need to provide a signal that goes from -VREG to VREG. That is understood. However, what i need to understand is that differential voltage thing and how i can make those sensors comply.
To resume, i don't know what to do with those sensors so that they are useful. Can anyone please give me a hint or something to push me in the right direction?
Thank you.
