DRV8302 Heating Up
Other Parts Discussed in Thread: DRV8302, TPS54360
Hi
I have been working on BLDC motor driver. I'm currently using DRV8302 driver. I followed the Application schematic present in the datasheet. I also followed the layout guidelines for PCB design. The Problem is the device heats up if powered, plus no voltage occurs between buck converter (22uH buck inductor) and ground. I am unable to figure out the problem. Any help would be helpful.
Thanks in Advance
Imthiaz
P.S : The Power Pad of the IC is connected to ground.
