DRV8835 - PWM controlling the DC motor
Guru 19785 points
Other Parts Discussed in Thread: DRV8835
Hello Team,
Please allow me to ask you a simple question. When driving the DC motor with PWM using in IN/IN mode, I believe you should control the motor repeating FORWARD and COAST, am I correct ? Or, would it be better to repeat FORWARD and BRAKE ?
Kawai
    This will depend on the actual application.
    The most common method for brushed DC motors is FORWARD/BRAKE. This will minimize the current ripple, but shorts the back-emf during the OFF period.
  • Hello Nicholas-san,
    Thank you for your support. Customer will use DRV8835 for camera Pan and Tilt application. Which control method would be the recommendation, FORWARD/BRAKE or FORWARD/COAST ?
    When PWM controlling with FORWARD/BRAKE, we are seeing large positive and negative current spikes. Is there a solution to reduce these current spikes ?
    It would be helpful if you could allow us to discuss off line, so that I could share customer measurement data.
    Kawai
    Thank you for your support. I am closing this post.
    Kawai
