DRV10975 included Step-down regulator
Other Parts Discussed in Thread: DRV10975
Hi there,
if I don't use the included step-down regulator of the DRV10975 driver, should I let the leave the pins VREG, SW and SWGND floating?  Or which minimum wiring would you recommend?
Thanks for your help,
Johannes
  • Hi Johannes,
    Regulator is use to power internally circuitry as well, so step down regulator needs to be configured in Linear/Buck regulator mode.  Since resistive energy is lost in linear regulator; Buck regulator is  more efficient compared to Linear Regulator.
    Krushal
