The DRV8301 datasheet says that "After the 16th clock cycle or when nSCS transitions from LOW to HIGH, the SDI shift register data is transferred into a latch where the input word is decoded."
This leads one to believe that you can simply pull down nSCS once per <read-command, data clock-out> pair of 16 bit transfers, since the first command should be committed after the 16th clock cycle. However, this did not work for me, I had to pulse nSCS high and low again between the read command, and the clock-out of the read data.
Can you please update the datasheet to make this explicit.
Oskar.
