[ DRV2605L ] Opeartion with Haptics Control Console
Other Parts Discussed in Thread: DRV2605L, DRV2605LEVM-MD
I think that I have found an error? on Haptics Control Console more specifically DRV2605L console.
In "Work Mode" setting, it seems that "External Edge Trigger" and "External Level Trigger" are swapped respectively.
I have tested DRV2605LEVM-MD with Haptics Control Console with DRV2605L console as following procedure.
(Not with DRV2605LEVM-MD console)
* Plug in -MD board to USB port
* Select target DRV2605L with B1 button (ex. OUT6 for LRA)
* Press "USB SW" button
* Open Haptics Control Console and DRV2605L console
In this set up, when I selected "External Edge Trigger" and apply DC voltage to PWM test point, DRV2605L attempts to keep LRA accelerating with selected library. On the other hand, if I chose "External Level Trigger", even though I apply DC voltage, DRV2605L play pattern only one time.
Can you please double check on your side and give me a feedback?
Ken
Othere reference
[ DRV2605L ] DRV2605LEVM-MD GUI Malfunction
https://e2e.ti.com/support/amplifiers/haptics/f/927/p/518339/1884499#1884499
