Other Parts Discussed in Thread: DRV8307
I have a motor with 3 hall sensor wires (single end). I connected all wires to DRV8307EVM board that following User's Guide step by step setup, but the motor didn't work normally when power turned on. The red LED is slowly flash always. The motor is overheat after turn on about 4 minutes. The motor stop run after rotated few seconds, then The motor run after stop few seconds. The motor is the work that is going on and off with red LED slow flashing. Could you tell me how to fix the issue?
