Other Parts Discussed in Thread: DRV110
hello
can i make the ipeak cureent limit higher than 0.9A by rducing the Rsense<1ohm ?
what is the maximum current peak and hild the part can handle?
hello
Hi Avraham,
Yes you can reduce Rsense , that's no DRV110 limitation since all power is externally dissipated. The external FET is the main limitation
The IR drop across Rsense should be>30mV for good Ipeak;Ihold accuracy
Costin
