Hi all
Would you mind if we ask DRV8306?
Please refer to the attachment file.
20190215_DRV8306.pdf
Could you give us advice?
Kind regards,
Hirotaka Matsumoto
Hi all
Kind regards,
Hirotaka Matsumoto
Adam san
Thank you so much for your reply.
When the motor is stopped, what is the method? Is the PWM reduced directly from 90% to 0%?
->Yes, they operate the PWM reduced directly from 90% to 0%.
Is there any braking used? Do they have access to the nBRAKE pin?
->We will confirm it. Using nBrake pin(pull-low?).
The nBRAKE input halts the motor by turning off all high-side MOSFETs and turning on all low-side MOSFETs when it is pulled low.
With turning on all low-side MOSFETs, according to slow decay, does it mean to prevent current flow from L to VM via FET's body diode?
And then, is it possbile to separate DRV8306's VM(+VDRAIN) and FET's VM(FET's drain voltage)?
With separating voltage, it is not recommend.
We assume that this affects for OCP protection operation and normal operation.
(It is necessary that DRV8306's VM(+VDRAIN) is more than FET's VM(FET's drain voltage).)
If you have some advice, could you let us know?
Kind regards,
Hirotaka Matsumoto
Adam san
OK, we got it.
Kind regards,
Hirotaka Matsumoto
