i want increase motor drive current, is set IDRIVE Pin Resistor  or Rsense? thanks.
If you wish to increase the peak drive current of the gate drivers, then you have to adjust the IDRIVE Pin resistor (configuration settings can be found in Table 5 of the datasheet).
If you wish to increase the maximum current through the motor windings, then you have to adjust Rsense and Vref (Equation 1 on the datasheet)\
