BOOSTXL-DRV8323RH: How to use POT
Part Number: BOOSTXL-DRV8323RH
Could you tell me about J3 Pin 11 on EVM?
1.Please tell me how to use this pin.
2.Does POT mean potentiometer?
3.Could you tell me an example of using POT?
BOOSTXL-DRV8323Rx EVM
http://www.tij.co.jp/jp/lit/ug/slvub01c/slvub01c.pdf
Yusuke
  • Yusuke,
    This stands for Potentiometer yes. In the normal code, this potentiometer is not utilized. It is there in case the end customer would like to change the MCU code and use that potentiometer for some purpose. You can add this in the code if you desire.
    -Adam
  • Adam-san,
    Thank you for your kind support.
    May I ask one more question?
    ”It is there in case the end customer would like to change the MCU code and use that potentiometer for some purpose. ”
    I don't know an example solution using POT.
    Could you give me your advice?
    Yusuke
  • Yusuke,
    In some cases where the customer needs to control the speed using hardware, they could use this POT on the EVM to adjust the output speed reference.
    -Adam
