BOOSTXL-DRV8323RS: 28069m Drv8323RS Rough Motor Id and High Current Draw
Part Number: BOOSTXL-DRV8323RS
I am using the 28069m with the 8323rs booster pack on J1, The supply is set to 13volts. I am using a 6355 190kv motor. I am having trouble identifying the motor and getting it to spin smoothly. After I enabled the system and run_identity, the motor makes a very loud whine noise and enters EST_State_Rs. It spins very roughly(loud and vibrant) at more than 5 amps, which is more than what I have configured as the USER_MOTOR_MAX_CURRENT. I haven't been able to go beyond the Rs estimation phase because the PSU cuts off at more than 5 amps. I not quite sure what's causing the problem.
I have attached the lab file and user files below. Any help would be appreciated.
/* --COPYRIGHT--,BSD
 * Copyright (c) 2012, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 * *  Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 * --/COPYRIGHT--*/
//! \file   solutions/instaspin_foc/src/proj_lab02c.c
//! \brief  All control from user code, only FAST�feedback from ROM
//! \brief	Special variable scaling for improved motor ID, especially with low inductance motors
//! (C) Copyright 2011, Texas Instruments, Inc.
//! \defgroup PROJ_LAB02c PROJ_LAB02c
//! \defgroup PROJ_LAB02c_OVERVIEW Project Overview
//! Run InstaSPIN�FOC from user memory (RAM/FLASH), only FAST�in ROM
//!	Special variable scaling for improved motor ID, especially with low inductance motors
// the includes
// system includes
#include <math.h>
#include "main.h"
#ifdef FLASH
#pragma CODE_SECTION(mainISR,"ramfuncs");
#endif
// Include header files used in the main function
// the defines
#define LED_BLINK_FREQ_Hz   5
// the globals
uint_least16_t gCounter_updateGlobals = 0;
bool Flag_Latch_softwareUpdate = true;
CTRL_Handle ctrlHandle;
#ifdef CSM_ENABLE
#pragma DATA_SECTION(halHandle,"rom_accessed_data");
#endif
HAL_Handle halHandle;
#ifdef CSM_ENABLE
#pragma DATA_SECTION(gUserParams,"rom_accessed_data");
#endif
USER_Params gUserParams;
HAL_PwmData_t gPwmData = {_IQ(0.0), _IQ(0.0), _IQ(0.0)};
HAL_AdcData_t gAdcData;
_iq gMaxCurrentSlope = _IQ(0.0);
#ifdef FAST_ROM_V1p6
CTRL_Obj *controller_obj;
#else
#ifdef CSM_ENABLE
#pragma DATA_SECTION(ctrl,"rom_accessed_data");
#endif
CTRL_Obj ctrl;				//v1p7 format
#endif
uint16_t gLEDcnt = 0;
volatile MOTOR_Vars_t gMotorVars = MOTOR_Vars_INIT;
#ifdef FLASH
// Used for running BackGround in flash, and ISR in RAM
extern uint16_t *RamfuncsLoadStart, *RamfuncsLoadEnd, *RamfuncsRunStart;
#ifdef CSM_ENABLE
extern uint16_t *econst_start, *econst_end, *econst_ram_load;
extern uint16_t *switch_start, *switch_end, *switch_ram_load;
#endif
#endif
_iq gLs_pu = _IQ30(0.0);
uint_least8_t gLs_qFmt = 0;
uint_least8_t gMax_Ls_qFmt = 0;
#ifdef DRV8301_SPI
// Watch window interface to the 8301 SPI
DRV_SPI_8301_Vars_t gDrvSpi8301Vars;
#endif
#ifdef DRV8305_SPI
// Watch window interface to the 8305 SPI
DRV_SPI_8305_Vars_t gDrvSpi8305Vars;
#endif
#ifdef DRV8323_SPI
// Watch window interface to the 8323 SPI
DRV_SPI_8323_Vars_t gDrvSpi8323Vars;
#endif
// the functions
void main(void)
  uint_least8_t estNumber = 0;
  uint_least8_t ctrlNumber = 0;
#endif
  // Only used if running from FLASH
  // Note that the variable FLASH is defined by the project
  #ifdef FLASH
  // Copy time critical code and Flash setup code to RAM
  // The RamfuncsLoadStart, RamfuncsLoadEnd, and RamfuncsRunStart
  // symbols are created by the linker. Refer to the linker files.
  memCopy((uint16_t *)&RamfuncsLoadStart,(uint16_t *)&RamfuncsLoadEnd,(uint16_t *)&RamfuncsRunStart);
  #ifdef CSM_ENABLE
    //copy .econst to unsecure RAM
    if(*econst_end - *econst_start)
        memCopy((uint16_t *)&econst_start,(uint16_t *)&econst_end,(uint16_t *)&econst_ram_load);
    //copy .switch ot unsecure RAM
    if(*switch_end - *switch_start)
        memCopy((uint16_t *)&switch_start,(uint16_t *)&switch_end,(uint16_t *)&switch_ram_load);
  #endif
  #endif
  // initialize the hardware abstraction layer
  halHandle = HAL_init(&hal,sizeof(hal));
  // check for errors in user parameters
  USER_checkForErrors(&gUserParams);
  // store user parameter error in global variable
  gMotorVars.UserErrorCode = USER_getErrorCode(&gUserParams);
  // do not allow code execution if there is a user parameter error
  if(gMotorVars.UserErrorCode != USER_ErrorCode_NoError)
      for(;;)
          gMotorVars.Flag_enableSys = false;
  // initialize the user parameters
  USER_setParams(&gUserParams);
  // set the hardware abstraction layer parameters
  HAL_setParams(halHandle,&gUserParams);
  // initialize the controller
  ctrlHandle = CTRL_initCtrl(ctrlNumber, estNumber);  		//v1p6 format (06xF and 06xM devices)
  controller_obj = (CTRL_Obj *)ctrlHandle;
#else
  ctrlHandle = CTRL_initCtrl(estNumber,&ctrl,sizeof(ctrl));	//v1p7 format default
#endif
    CTRL_Version version;
    // get the version number
    CTRL_getVersion(ctrlHandle,&version);
    gMotorVars.CtrlVersion = version;
  // set the default controller parameters
  CTRL_setParams(ctrlHandle,&gUserParams);
  // setup faults
  HAL_setupFaults(halHandle);
  // initialize the interrupt vector table
  HAL_initIntVectorTable(halHandle);
  // enable the ADC interrupts
  HAL_enableAdcInts(halHandle);
  // enable global interrupts
  HAL_enableGlobalInts(halHandle);
  // enable debug interrupts
  HAL_enableDebugInt(halHandle);
  // disable the PWM
  HAL_disablePwm(halHandle);
#ifdef DRV8301_SPI
  // turn on the DRV8301 if present
  HAL_enableDrv(halHandle);
  // initialize the DRV8301 interface
  HAL_setupDrvSpi(halHandle,&gDrvSpi8301Vars);
#endif
#ifdef DRV8305_SPI
  // turn on the DRV8305 if present
  // initialize the DRV8305 interface
  HAL_setupDrvSpi(halHandle,&gDrvSpi8305Vars);
#endif
#ifdef DRV8323_SPI
  // turn on the DRV8323 if present
  // initialize the DRV8323 interface
  HAL_setupDrvSpi(halHandle,&gDrvSpi8323Vars);
  gDrvSpi8323Vars.Ctrl_Reg_06.CSA_GAIN = Gain_20VpV;
  gDrvSpi8323Vars.Ctrl_Reg_06.VREF_DIV = 1;
  gDrvSpi8323Vars.WriteCmd = true;
  HAL_writeDrvData(halHandle,&gDrvSpi8323Vars);
  gDrvSpi8323Vars.ReadCmd = true;
  HAL_readDrvData(halHandle,&gDrvSpi8323Vars);
#endif
  // enable DC bus compensation
  CTRL_setFlag_enableDcBusComp(ctrlHandle, true);
  for(;;)
    // Waiting for enable system flag to be set
    while(!(gMotorVars.Flag_enableSys));
#ifdef DRV8323_SPI
#endif
    // loop while the enable system flag is true
    while(gMotorVars.Flag_enableSys)
        CTRL_Obj *obj = (CTRL_Obj *)ctrlHandle;
        // increment counters
        gCounter_updateGlobals++;
        if(CTRL_isError(ctrlHandle))
            // set the enable controller flag to false
            CTRL_setFlag_enableCtrl(ctrlHandle,false);
            // set the enable system flag to false
            // disable the PWM
        else
            // update the controller state
            bool flag_ctrlStateChanged = CTRL_updateState(ctrlHandle);
            // enable or disable the control
            CTRL_setFlag_enableCtrl(ctrlHandle, gMotorVars.Flag_Run_Identify);
            if(flag_ctrlStateChanged)
                CTRL_State_e ctrlState = CTRL_getState(ctrlHandle);
                EST_State_e estState = EST_getState(obj->estHandle);
                if(ctrlState == CTRL_State_OffLine)
                    // enable the PWM
                    HAL_enablePwm(halHandle);
                else if(ctrlState == CTRL_State_OnLine)
                    if((estState < EST_State_LockRotor) || (estState > EST_State_MotorIdentified))
                        // update the ADC bias values
                        HAL_updateAdcBias(halHandle);
                    // Return the bias value for currents
                    gMotorVars.I_bias.value[0] = HAL_getBias(halHandle,HAL_SensorType_Current,0);
                    gMotorVars.I_bias.value[1] = HAL_getBias(halHandle,HAL_SensorType_Current,1);
                    gMotorVars.I_bias.value[2] = HAL_getBias(halHandle,HAL_SensorType_Current,2);
                    // Return the bias value for voltages
                    gMotorVars.V_bias.value[0] = HAL_getBias(halHandle,HAL_SensorType_Voltage,0);
                    gMotorVars.V_bias.value[1] = HAL_getBias(halHandle,HAL_SensorType_Voltage,1);
                    gMotorVars.V_bias.value[2] = HAL_getBias(halHandle,HAL_SensorType_Voltage,2);
                    // enable the PWM
                else if(ctrlState == CTRL_State_Idle)
                    // disable the PWM
                    gMotorVars.Flag_Run_Identify = false;
                if((CTRL_getFlag_enableUserMotorParams(ctrlHandle) == true) &&
                  (ctrlState > CTRL_State_Idle) &&
                  (gMotorVars.CtrlVersion.minor == 6))
                    // call this function to fix 1p6
                    USER_softwareUpdate1p6(ctrlHandle);
        if(EST_isMotorIdentified(obj->estHandle))
            // set the current ramp
            EST_setMaxCurrentSlope_pu(obj->estHandle,gMaxCurrentSlope);
            gMotorVars.Flag_MotorIdentified = true;
            // set the speed reference
            CTRL_setSpd_ref_krpm(ctrlHandle,gMotorVars.SpeedRef_krpm);
            // set the speed acceleration
            CTRL_setMaxAccel_pu(ctrlHandle,_IQmpy(MAX_ACCEL_KRPMPS_SF,gMotorVars.MaxAccel_krpmps));
            if(Flag_Latch_softwareUpdate)
              Flag_Latch_softwareUpdate = false;
              USER_calcPIgains(ctrlHandle);
        else
            // the estimator sets the maximum current slope during identification
            gMaxCurrentSlope = EST_getMaxCurrentSlope_pu(obj->estHandle);
        // when appropriate, update the global variables
        if(gCounter_updateGlobals >= NUM_MAIN_TICKS_FOR_GLOBAL_VARIABLE_UPDATE)
            // reset the counter
            updateGlobalVariables_motor(ctrlHandle);
        if(CTRL_getMotorType(ctrlHandle) == MOTOR_Type_Induction)
            // recalculate Kp and Ki gains to fix the R/L limitation of 2000.0, and Kp limit to 0.11
            recalcKpKi(ctrlHandle);
            // set electrical frequency limit to zero while identifying an induction motor
            setFeLimitZero(ctrlHandle);
            // calculate Dir_qFmt for acim motors
            acim_Dir_qFmtCalc(ctrlHandle);
        else
        	// as well as recalculates gains based on estimator state to allow low inductance pmsm to id
        	recalcKpKiPmsm(ctrlHandle);
            // calculate an Ls qFmt that allows ten times smaller inductance compared to Lhf
            CTRL_calcMax_Ls_qFmt(ctrlHandle, &gMax_Ls_qFmt);
            gLs_pu = EST_getLs_d_pu(obj->estHandle);
            gLs_qFmt = EST_getLs_qFmt(obj->estHandle);
        // enable/disable the forced angle
        EST_setFlag_enableForceAngle(obj->estHandle,gMotorVars.Flag_enableForceAngle);
        // enable or disable power warp
        CTRL_setFlag_enablePowerWarp(ctrlHandle,gMotorVars.Flag_enablePowerWarp);
#ifdef DRV8301_SPI
        HAL_writeDrvData(halHandle,&gDrvSpi8301Vars);
        HAL_readDrvData(halHandle,&gDrvSpi8301Vars);
#endif
#ifdef DRV8305_SPI
        HAL_writeDrvData(halHandle,&gDrvSpi8305Vars);
        HAL_readDrvData(halHandle,&gDrvSpi8305Vars);
#endif
#ifdef DRV8323_SPI
#endif
      } // end of while(gFlag_enableSys) loop
    // disable the PWM
    // set the default controller parameters (Reset the control to re-identify the motor)
  } // end of for(;;) loop
} // end of main() function
interrupt void mainISR(void)
  // toggle status LED
  if(++gLEDcnt >= (uint_least32_t)(USER_ISR_FREQ_Hz / LED_BLINK_FREQ_Hz))
    HAL_toggleLed(halHandle,(GPIO_Number_e)HAL_Gpio_LED2);
    gLEDcnt = 0;
  // acknowledge the ADC interrupt
  HAL_acqAdcInt(halHandle,ADC_IntNumber_1);
  // convert the ADC data
  HAL_readAdcData(halHandle,&gAdcData);
  // run the controller
  CTRL_run(ctrlHandle,halHandle,&gAdcData,&gPwmData);
  // write the PWM compare values
  HAL_writePwmData(halHandle,&gPwmData);
  // setup the controller
  CTRL_setup(ctrlHandle);
  if(CTRL_getMotorType(ctrlHandle) == MOTOR_Type_Pm)
      // reset Ls Q format to a higher value when Ls identification starts
      CTRL_resetLs_qFmt(ctrlHandle, gMax_Ls_qFmt);
  return;
} // end of mainISR() function
void updateGlobalVariables_motor(CTRL_Handle handle)
  CTRL_Obj *obj = (CTRL_Obj *)handle;
  // get the speed estimate
  gMotorVars.Speed_krpm = EST_getSpeed_krpm(obj->estHandle);
  // get the real time speed reference coming out of the speed trajectory generator
  gMotorVars.SpeedTraj_krpm = _IQmpy(CTRL_getSpd_int_ref_pu(handle),EST_get_pu_to_krpm_sf(obj->estHandle));
  // get the magnetizing current
  gMotorVars.MagnCurr_A = EST_getIdRated(obj->estHandle);
  // get the rotor resistance
  gMotorVars.Rr_Ohm = EST_getRr_Ohm(obj->estHandle);
  // get the stator resistance
  gMotorVars.Rs_Ohm = EST_getRs_Ohm(obj->estHandle);
  // get the stator inductance in the direct coordinate direction
  gMotorVars.Lsd_H = EST_getLs_d_H(obj->estHandle);
  // get the stator inductance in the quadrature coordinate direction
  gMotorVars.Lsq_H = EST_getLs_q_H(obj->estHandle);
  // get the flux in V/Hz in floating point
  gMotorVars.Flux_VpHz = EST_getFlux_VpHz(obj->estHandle);
  // get the controller state
  gMotorVars.CtrlState = CTRL_getState(handle);
  // get the estimator state
  gMotorVars.EstState = EST_getState(obj->estHandle);
  // Get the DC buss voltage
  gMotorVars.VdcBus_kV = _IQmpy(gAdcData.dcBus,_IQ(USER_IQ_FULL_SCALE_VOLTAGE_V/1000.0));
  return;
} // end of updateGlobalVariables_motor() function
void CTRL_resetLs_qFmt(CTRL_Handle handle, const uint_least8_t Ls_qFmt)
  static bool LsResetLatch = false;
  if(EST_getState(obj->estHandle) == EST_State_Ls)
      if((EST_getLs_d_pu(obj->estHandle) != _IQ30(0.0)) && (LsResetLatch == false))
          EST_setLs_qFmt(obj->estHandle, Ls_qFmt);
          LsResetLatch = true;
  else
  return;
} // end of CTRL_resetLs_qFmt() function
void recalcKpKiPmsm(CTRL_Handle handle)
  EST_State_e EstState = EST_getState(obj->estHandle);
  if((EST_isMotorIdentified(obj->estHandle) == false) && (EstState == EST_State_Rs))
      float_t Lhf = CTRL_getLhf(handle);
      float_t Rhf = CTRL_getRhf(handle);
      float_t RhfoverLhf = Rhf/Lhf;
      _iq Kp = _IQ(0.05*Lhf*USER_IQ_FULL_SCALE_CURRENT_A/(USER_CTRL_PERIOD_sec*USER_IQ_FULL_SCALE_VOLTAGE_V));
      _iq Ki = _IQ(RhfoverLhf*USER_CTRL_PERIOD_sec);
      _iq Kp_spd = _IQ(0.005*USER_IQ_FULL_SCALE_FREQ_Hz*USER_MOTOR_MAX_CURRENT/USER_IQ_FULL_SCALE_CURRENT_A);
      // set Rhf/Lhf
      CTRL_setRoverL(handle,RhfoverLhf);
      // set the controller proportional gains
      CTRL_setKp(handle,CTRL_Type_PID_Id,Kp);
      CTRL_setKp(handle,CTRL_Type_PID_Iq,Kp);
      // set the Id controller gains
      CTRL_setKi(handle,CTRL_Type_PID_Id,Ki);
      PID_setKi(obj->pidHandle_Id,Ki);
      // set the Iq controller gains
      CTRL_setKi(handle,CTRL_Type_PID_Iq,Ki);
      PID_setKi(obj->pidHandle_Iq,Ki);
      // set speed gains
      PID_setKp(obj->pidHandle_spd,Kp_spd);
  else if(EstState == EST_State_RatedFlux)
      _iq Ki_spd = _IQ(0.5*USER_IQ_FULL_SCALE_FREQ_Hz*USER_CTRL_PERIOD_sec*USER_MOTOR_MAX_CURRENT/USER_IQ_FULL_SCALE_CURRENT_A);
      // Set Ki on closing the feedback loop
      PID_setKi(obj->pidHandle_spd,Ki_spd);
  else if(EstState == EST_State_RampDown)
      _iq Kp_spd = _IQ(0.02*USER_IQ_FULL_SCALE_FREQ_Hz*USER_MOTOR_MAX_CURRENT/USER_IQ_FULL_SCALE_CURRENT_A);
      _iq Ki_spd = _IQ(2.0*USER_IQ_FULL_SCALE_FREQ_Hz*USER_CTRL_PERIOD_sec*USER_MOTOR_MAX_CURRENT/USER_IQ_FULL_SCALE_CURRENT_A);
      // Set Kp and Ki of the speed controller
      TRAJ_setTargetValue(obj->trajHandle_spdMax,_IQ(USER_MOTOR_RES_EST_CURRENT/USER_IQ_FULL_SCALE_CURRENT_A));
  return;
} // end of recalcKpKiPmsm() function
void CTRL_calcMax_Ls_qFmt(CTRL_Handle handle, uint_least8_t *pLs_qFmt)
  if((EST_isMotorIdentified(obj->estHandle) == false) && (EST_getState(obj->estHandle) == EST_State_Rs))
	  float_t fullScaleInductance = USER_IQ_FULL_SCALE_VOLTAGE_V/(USER_IQ_FULL_SCALE_CURRENT_A*USER_VOLTAGE_FILTER_POLE_rps);
	  float_t Ls_coarse_max = _IQ30toF(EST_getLs_coarse_max_pu(obj->estHandle));
	  int_least8_t lShift = ceil(log((Lhf/20.0)/(Ls_coarse_max*fullScaleInductance))/log(2.0));
	  *pLs_qFmt = 30 - lShift;
  return;
} // end of CTRL_calcMax_Ls_qFmt() function
void recalcKpKi(CTRL_Handle handle)
      _iq Kp = _IQ(0.25*Lhf*USER_IQ_FULL_SCALE_CURRENT_A/(USER_CTRL_PERIOD_sec*USER_IQ_FULL_SCALE_VOLTAGE_V));
      // set Rhf/Lhf
  return;
} // end of recalcKpKi() function
void setFeLimitZero(CTRL_Handle handle)
  _iq fe_neg_max_pu;
  _iq fe_pos_min_pu;
  if((EST_isMotorIdentified(obj->estHandle) == false) && (CTRL_getMotorType(handle) == MOTOR_Type_Induction))
	  fe_neg_max_pu = _IQ30(0.0);
	  fe_pos_min_pu = _IQ30(0.0);
  else
	  fe_neg_max_pu = _IQ30(-USER_ZEROSPEEDLIMIT);
	  fe_pos_min_pu = _IQ30(USER_ZEROSPEEDLIMIT);
  EST_setFe_neg_max_pu(obj->estHandle, fe_neg_max_pu);
  EST_setFe_pos_min_pu(obj->estHandle, fe_pos_min_pu);
  return;
} // end of setFeLimitZero() function
void acim_Dir_qFmtCalc(CTRL_Handle handle)
  if(EstState == EST_State_IdRated)
      EST_setDir_qFmt(obj->estHandle, EST_computeDirection_qFmt(obj->estHandle, 0.7));
  return;
} // end of acim_Dir_qFmtCalc() function
//@} //defgroup
// end of file
4606.user_j1.h
7142.user.h
