Hi Friends,
I would like to use DRV8839DSSR motor driver for one of my projects.
The control signals (input and Enable) are from a microcontroller of 3.3V.
Vm =7V.
If Vcc is connected to 7V will it work?
Hi Friends,
Vm =7V.
We do not recommend connecting VM and VCC together at 7V. When VM and VCC are connected, a voltage spike on the motor load can cause VM to exceed 7V and violate the absolute maximum VCC voltage of 7V. We recommend lowering the voltage on VCC. Please consider using the 3.3V MCU supply to provide VCC to the DRV8839.
The 3.3V logic inputs are marginal to switch the on-off states when VCC is 7V. We recommend lowering the voltage on VCC.
