Other Parts Discussed in Thread: DRV10983, , DRV10987
1. Can you please confirm whether the automotive version (Q1) has a different register set, specifically with regards to Fault Registers? It seems the Q1 version clears those flags by writing 0xFF to the register, while the non-Q1 version clears the flags simply by starting the motors. The non-Q1 version FaultReg is read only.
2. Is Lock0 reset if a fault persists? If so, what is the timing between clearing and re-setting Lock0?
3. Is there a limit for retrying the motor after a lock fault, e.g., is there a lockout feature that requires different action to restart the motor after a given number of attempts?
Thank you!
