Part Number: BOOSTXL-DRV8320S
Hi All,
I wanted to ask you for help.
I use a BOOSTXL-DRV8320S-EVM to control a motor, it has built-in sensors
How do you connect the hall effect sensors to the board to do the sensored control?
Directly to the connection pins of J5 or do I need to make an auxiliary circuit to adapt the signal?
Attached motor data sheet.
Thank you very much
Gonzalo7875.DB59S024035-A.pdf
