I would like to know if the TPS2561ADRC has some backdrive protection.
If the OUT pins have a voltage apply on them but the IN is floating (0V) and EN pins is low @ 0V, will there be some backdrive current flowing from the OUT pins to the IN pins that could create a voltage on the IN pins?
I realized it is not a case that is quite possible for an USB application. I am using this device of a different application.
Thank You !
