Other Parts Discussed in Thread: TPS61021A
Hi Sir,
I am in charge of a IoT project. I plan to use TPS22917 to bypass battery voltage while power saving mode.
Here is the schematic, the boost convert(TPS61021A) will be cut-off if the system stays PSM mode, then battery will provide the power directly through TPS22917.
I want to make sure whether the current leakage occurs from TPS61021A Vout?
