BQSTUDIO: BQStudio : How to program df.fs and bq.fs files in BQStudio?
Part Number: BQSTUDIO
We have completed the learning cycle of the battery and we have got update status as 6.
We created the golden image which has .srec, df.fs and bq.fs files. In BQStudio, using programming tab we can are able to program only .srec file.
We wanted to know how to program df.fs and bq.fs files using BQStudio.
Thanks and Regards,
Sudha Nayak
  • Hello Sudha,
    Which gauge is this for? Some gauges have a different bqStudio format. In eneral you should be able to go to the programming tab and click browse, then click the drop down menu for the file extension and select the flash stream file to search for and program.
    Sincerely,
    Wyatt Keller
