I'm in the process of implementing writing the golden image to the bq34z100-g1 as described in slua665. I performed the mass erase and then reset the device intending to read back data flash and verify that the erase worked. But after the reset, the only address that the gauge would respond to is General Call (0x00). I tried all even addresses from 0 to 254. I removed power for many minutes to make sure any capacitors had discharged and still no luck. I tried General Call command 0x06 "Reset and write programmable part of slave address by hardware" but that didn't do anything either.
Is there any way to recover the gauge?
Keith
