Hello team,
My customer is using the TPS7H1101HKR/EM on a project, and they are planning on pulling up the PG pin to a separate voltage other than VOUT. Can you confirm that PG is always pulled down unless VOUT is above its threshold (roughly 80% according to the datasheet)?
They are concerned that during startup (before there is any voltage on VIN) that the power-good pin will be in a Hi-Z state allowing the voltage from my pull up to make the power good signal high.
Thank you in advance for your support!
Errol
