Other Parts Discussed in Thread: TIDA-050045,
The data sheet specifies that the value of Rden should be 25.5k. However, reference design TIDA-050045 and the TPS23730EVM-093 eval module both use 27.4k resistors.
Which is correct? Or is it to compensate for the lower resistance of the FET-diode bridge compared to the all diode bridge that the TPS23730 assumes?
David
