TPS65295: Decoupling caps
Part Number: TPS65295
I see the power decoupling guidelines that make use of 10uF, 1uF, 0.1uF caps on a single voltage rail.   Does this create issues with resonance? Since I have 1uF caps in the same 0402 size as 0.1uF caps,
I would like to simply use the largest capacitance available in a given package.  What is the impact of this approach?  I also have very tight space requirements so working to get something robust over temperature but not take up extra space unnecessarily.  Please comment and advise.
Thank you,
HSG
