Other Parts Discussed in Thread: TPS23756
Hi team,
My customer is looking for second source solution for TPS23754.
I have discussed with customer about TPS23756.
The only difference is the TPS23754 device has a 15-V converter start-up while the TPS23756 device has a 9-V converter startup.
Therefore, customer would like to confirm whether they will need to change the transformer circuit and surrounding circuit of TPS23754 to feed the for TPS23756 feature.
Or do you have other recommended solution which can replace TPS23754 directly.
Thanks.
