Hi team,
Customer is using TPS7A91 in their system generate 1.8V, they use 0.1uF SS cap, and find the output voltage get a small overshoot to 1.8V, then drop ~40mV down to 1.76V, later slow back to 1.8V; below is their test waveform and schematic, could you help check if this is normal and why there is happen?
Will
