Hi All,
One of our Apollo lake notebook projects uses tps650940 for PMIC design, and the DDR is LDDR3. But we encountered a problem, VTT has no output, and both the input and EN (S0) have signal at present.
From the datasheet we know that TPS650941 is suitable for LDDR3, and we have used TPS650940 for LPDDR4 design before, and it has in MP status. But now we have changed to LPDDR3 due to other reasons, we also tried to increase VDDQ voltage to 1.2V, but VTT still has no output yet.
We have checked other circuit designs, all other signals are normally, and the machine can be turned on now. But the VTT voltage is actually not output (We disconnected all loads of VTT and measured its output and found no signal), the timing and signal of the PMIC are OK.
We want to know whether VTT has no output is affected by I2C and OTP, or tps650940 does not support LDDR3 at all? I added our schematic diagram to the below and hope it can help for the analyse.
Best Regards
