I am not quite sure about the ESR requirements on Cout for the TPS51315/TPS59116. In D-CAP Mode, to keep the loop stable, the ESR or Cout or both should be large enough. Howvere, to get the required feedback signal, the data sheet mentioned the ESR shoud meet the required ripple. Is the ESR the minimum or maximum value to meet the required ripple, or the ESR is where it should be? Thank you.
Chun-Te Li
