LMG3410R070: IN pin terminal capacitance - LMG3410E070
Part Number: LMG3410R070
Can you please confirm input terminal capacitance @ IN pin? The PWM on the IN pin shows more delay compared to used RC(1k/47pF) filter @ 500 kHz application. is there any delay/Hold operation between IN pin and actual Turn On instant? I also tried 47R/47pF (near to what suggested in application, however it may not be more immune to noise. Please suggest.
  • Hello, thank you for your question. The propagation delay is 20 ns, as noted in page 7 of the data sheet
    In regards to the noise concern, could you please provide additional information such as waveforms? These noise concerns could be potentially be attributed to the layout; to address the noise problem, a revision of the RC filter may be needed.
