Needing more mA'age than USB 2.0 VBUS can supply, I'm using a TPS62143 from a 12v mains supply (PVIN connected to AVIN).
If I tie EN to 12v then all is good.
If I tie EN to VBUS (ie 5v) so I get power only when USB connected, then all is good if the 12v supply is active.
If I connect VBUS before 12v then the part appears to briefly powerup, then permanently die.
Can someone please point me to the section in the datasheet that explains why this is a bad design idea please
Kind regards
Bruce.
