TPS65251: Hiccup mode
Part Number: TPS65251
Hi Team,
Can I remove an inductor while all the output ENABLE pins are in enable mode and expect that hiccup mode will not be induced by removing an inductor?
I was unable to determine if hiccup mode is entered through an internal measurement of the top FET alone, or if it needs to pass through the external network including the inductor. The datasheet appears to indicate this might be an internal loop.
Thank you.
-Mark
