BQ76940: Device_XReady bit
Part Number: BQ76940
Hi TI team
As the spec say, any internal fault will set Device_XReady bit. My concern is whether this bit will be set by the below internal faults, eg
  • ADC convertor stop working,
  • ADC reference voltage unstable,
  • RAM,
  • Register
  • Clock
  • Hi Iuo,
    No, XREADY only checks for communication faults internal.  See figure 10 of the application note https://www.ti.com/lit/pdf/slua775 for internal communication paths.  There may be limited checks of some clocks by default of the normal operation, for example if the clock on the middle group stopped the interface could not respond and XREADY would be set.  The registers will not update in this condition without other indication.
