I am Koki Tsushima, who is FAA.
My account concerns that Is there possibility to act as following order.
1. Turn off
2. FAULT activated
I think this could be happed because when overcurrent was detected, the signal transit to FAULT after 8ms.
Between that 8 seconds, if thermal protected is activated, FET will turn off immediately in ideal situation.
This cause the result that TPS25200 will turn off before FAULT will be activated.
But I am concerns that there is delay time a few seconds to transit signal from Thermal sense to Driver.
For ideal, it should be done at the same time, but it cannot be come true for circuit.
If you know the sharp time for sending signal from Thermal sense to Driver, please tell me.
Thank you,
Koki Tsushima
