Jeita standard with CE marking
Part Number: BQ51051B
Hello there,
It defines the temperatures at which the voltage of the battery should be 0-45 degrees Celsius for the li-po battery used in our products. This is how most li-ion and li-po batteries appear to be.
However, devices that have used the battery voltage (Texas Bq51051) support the Jeita standard. In this standard, the voltage of the battery is not cut off until 45 degrees Celsius, the charge reduces the voltage and voltage at degrees Celsius, and is cut off against voltage at 60 degrees Celsius.
However, when we want to get CE certification for our products, the jeita charging profile gives us trouble since the test center battery manufacturer gives the maximum charging temperature as 45 degrees Celsius.
We would like to know your thoughts on this grudge.
Best regards.
