Other Parts Discussed in Thread: LP87332B-Q1, , LP87332D
Hi team,
Since LP87332D-Q1 is out of stock, can replace LP87332D-Q1 with LP87332B-q1 without any change? Thanks!
Jiawei
Hi team,
Jiawei
Hello Jiawei,
LP87332D-Q1 has default output voltages of 1.15V, 1.06V, 3.3V, and 3.3V. LP87332B-Q1 has default output voltages of 1.255V, 3.3V, 3.3V, and 3.3V. So it won't be a drop-in replacement.
Thanks.
Tomi Koskela
Hi Koskela,
Customer wanted voltage is 1.15V, 1.15V, 3.3V, 3.3V. I think they can change corresponding register to get their wanted voltage output, so they can use same code to get same voltage in LP87332D or LP87332B, right?
jiawei
Hi Jiawei,
Yes if they can change the voltages through I2C writes that is doable. Note the registers are volatile memory, so the settings will be lost on power down. So the write has to be done on each power up.
Thanks.
Tomi Koskela
