LP8866-Q1: I2C doesn't response ACK
Part Number: LP8866-Q1
Hi team,
In below design, we found the Bit 9/ACK is always high. We checked the schematics, changed Pin 33/MODE resistor to 11kohm/1%, and demounted other devices on the same I2C bus. LP8866 still doesn't response ACK. Is there anything else that I could try?
Thanks.
Below is the same I2C write to EVM. You could see the ACK bit is pulled low.
