Hi Team,
Could you help to review this TPS62424 SCH?
Thanks!
Hi Amelie,
Thank you for sharing the information. I am closing the thread.
Tanvee
Hi Tanvee,
During customer design, they have a question about timing.'
Because of the power timing problem (TPS62424 has a faster startup time, customer need the 2.9V LDO voltage output time to be faster than the startup time of the TPS62424), so customer needs a delay for TPS62424. So customer change SCH as following:
Hi Amelie,
RC circuit on enable pin help to add delay on start up. If they want precise delay then I would suggest to follow below document.
This documents help to calculate delay for enable for start up.
Tanvee
