Hi team,
Could you confirm that the soft start time setting of TPSM82813 can be extended to 10ms? Thank you!
Sam Ting
Hi Sam,
Yes, the soft-start time setting can be extended up to 10ms by using a larger capacitor, like described in equation 9.
It should be considered that the capacitor will take more time to discharge, since the pull-down resistor of the SS pin is around 1kOhms.
Davor
