Other Parts Discussed in Thread: UA78, TPS7A49, , TPS7A24
Hi Team,
Now customer use MC78L08ABDR2G !
There is a good new that we have a chance to DIN
Do we have a solution to compete with MC78L08ABDR2G? (If P2P & new product would be better)
Hey Kygo,
The UA78 should have options, I found it using https://bomcross.ti.com/en/search?searchTerm=MC78L08ABDR2G
Yes, you're right!
1. But UA78L08ACDRG4 seems to be an old product, could you recommend a new product to me?
2. I saw the difference between the UA78L08ACDRG4 & MC78L08ABDR2G , what is JESD-609 Code? THX
Hey Kygo,
The E3 on MC78L08ABDR2G indicates that it contains Sn (tin), the E4 on UA78L08ACDRG4 indicates that it plated a non-Sn plating.
JESD-609: "This standard describes the marking of components and the labeling of their shipping containers to identify their 2nd level terminal finish or material, and applies to components that are intended to be attached to boards or assemblies with solder or mechanical clamping or are press fit."
As for newer part, we certainly have much more modern LDOs (UA78L is several decades old). TPS7A24 or TPS7A49 could be good replacements depending on their exact needs. Below is a quick spec comparison.
