Team,
Could you please let me know the top marking for PTPS659413F0RWERQ1 and PTPS659411F0RWERQ1.
Thanks.
Arun
Team,
Thanks.
Arun
The pre-released silicon revision devices PTPS659413F0RWERQ1, PTPS659411F0RWERQ1, and PTPS659414F4RWERQ1 will have the following top markings:
First Line | PTPS659X |
Second | AXL2-Q1 (AX TI inforamtion, L2 TI Information) |
Third | TI YMG |
Fourth | MLLL G4 |
There is no distinction in the top marking between these devices. The final silicon revision released to production will have the following top markings.
First | TPS6594 |
Second | ABCD-Q1 (ABCD NVM Configuration) |
Third | TI YMG |
Fourth | MLLL G4 |
With the TPS65941111RWERQ1, the "ABCD" is "1111".
With the TPS65941212RWERQ1, the "ABCD" is "1212".
If the "ABCD" field is "XXXX", then this is a pre-production sample (not the ones described above) and you should work with your representative which requested the sample to identify the devices.
Chris
