Hi team,
My customer will design fixed output voltage version-
PPS74512PQWDRBRQ1
So could you advise how to connect FB pin? is it directly connected to OUT pin?
Hi team,
Hi Paul,
The PG is open-drain topology and so needs a pull up resistor between the PG pin and the voltage it is being pulled up to. Please see the applications schematics that I got from the datasheet as an example.
The pull-up voltage does not have to be Vout, but in general we recommend that the pull-up voltage be either Vout or Vin in order to eliminate the indeterminant PG voltage during a slow startup. The Supervisor product line has published an app note covering this in more detail if you are interested in more detail. https://www.ti.com/lit/an/snva845/snva845.pdf
