Hello Alex,
We do not characterize for forced air (different LFM ratings) like heatsinks. Forced air would likely have a small effect since the thermal resistance is lowest through the pad and thus your PCB layout would be best for dissipating heat without a heatsink on the case top.
Sincerely,
Wyatt Keller
Hi Wyatt,
Thanks, but this did not answer my original question: Do you have a physical temperature spec for the device itself (case or junction)?
Hello Alex,
Gauges do not usually need much heat dissipation because there is no high currents through them. The -40degC and 85degC values are given for the ambient temperature which the case would also be forced to. I would relate the temperature specification to the case temperature.
Sincerely,
Wyatt Keller
