Other Parts Discussed in Thread: TPS22965, TPS53355
Is there any substitute material for TPS53353?
Is there any substitute material for TPS22965?
In regards to substitute material for the TPS53353, you may use the TPS53355, which is a pin-to-pin compatible, higher current version of the part.
Alec Biesterfeld
As for TPS22965, you should submit a new thread with only TPS22965 in title. Then dedicated engineer will help you.
We will close this thread first.
Lishuang
