Hi I need help to do frequency loop analysis of my circuit to check the phase and gain margin of circuit.
what are all parameters we need to add for the current loop of LM5116 IC in the attached model.\
Hi Timothy,
Thank you for the response.
I want to design the compensation for particular phase margin, i used the webbench design tool for this but i want to check the result in frequency analysis.
Hi Venkata,
The quickstart calculator will allow you to do that most efficiently.
https://www.ti.com/tool/LM5116-5116WG-25116DESIGN-CALC
Tim
Hi TIm,
I have used this design calculator,i want to verify the compensation with frequency analysis simulation based on TINA.
For this what are all parameters we need to add for the current loop of LM5116 IC in previously attached model.
Ventaka,
I may be able to get our modeling team to take a look. In the meantime, the internal current sense parameters (gain, etc.) are available in the LM5116 datasheet.
Tim
Ventaka,
I have informed the modeling team of this. What parameters in the current loop are the main concern so they know what to focus on?
Tim
Ventaka, in the meantime you might try using WEBENCH to check LM5116 as needed.
Tim
Hi Tim ,
Yes i have used the webbench to check LM5116.
The results with webbench design and LM5116 design calculator are not matching. I tried to put the same values in both cases.
Ventaka,
The output cap value is critical. Make sure the ceramic capacitance is derated for applied voltage.
Tim
Hi Ventaka,
Recommendation is to try the already available PSPICE average model in the LM5116 product folder. All the internal parameters are already modeled as per the requirements. You can adjust the external compensation circuit values to meet your requirements.
Average model link: https://www.ti.com/lit/zip/snvm346
Also here is the link that explains the process of importing from one tool to another -- in this case importing a PSPICE model to TINA:
Tim
