To set an output voltage of -15.5V, Webench recommends a 205k resistor for Rset. (11-34V input, -15.5V output, 60C operating temp)
The datasheet specifies using 187k resistor for Rset to get -15.5V output.
See Table 3 of the datasheet.
Please advise.
Hello Matthew,
Please use the value(s) shared on Table 3 of the datasheet.
Thanks for bringing up the following information. I will make sure to notify the internal team of this bug.
Alejandro
Thank you Alejandro.
I noticed in the webench design, any output voltage between -15.5 to -17 would give an Rset value of 205k. Lowering the output voltage to -15.0V gave the correct Rset resistor value.
Matthew
Thanks for sharing! I'll make sure to notify the team.
Kind regards,
Alejandro
